Sync update for my 2023 Badlands with Nav - doesn't work for my 2022 Bigbend no Nav
Summit
East of Nashville
Currently I see this on my 2022 Bigbend
Ford Bronco Sport Sync update for my 2023 Badlands with Nav - doesn't work for my 2022 Bigbend no Nav Sync BIGBEND
I just did the USB Update for the 2023 Badlands w/Nav
I think I've seen this before here but
I can not use the update for my 2023 Badlands w/Nav for my 2022 Bigbend no NAV
So looks like I need to do an update specifically for the Bigbend no NAV
It does appear I need to update the 2022 Bigbend from what I see on the screen
You are correct about no NAV
The current Sync is 23188
Mwittke5857
Elma, NY
2021 Bronco
Ford wasn't about to make it that easy to add Nav :mad:
Kamikaze9000
'24 BS Outerbanks, '14 Fiesta ST, '16 Focus ST
You can pull the Sync 3 module with nav from another vehicle (must be for the same size screen). Youll have to deal with some adjustments to the programming (use an as-built for a similarly equipped BS but with nav) with forscan. When you do upgrades for sync, youll have to use a vin for a BS with nav.
Personally, i find apple carplay to be better than the command structure and constantly out of date nav on sync 3. But, it is a decent backup option when you lose cellular connection.
Mwittke5857
Elma, NY
2021 Bronco
Im sorta with Kamikaze on the Nav, I use Google through my iPhone. It constantly does updates and reroute you around heavy traffic which to my knowledge, my "Not so Eco, Not so Sport" never did
