To a point, I agree narrow tires will "dig" but after getting stuck with "diggers" on my old CJ5 several times, I went with MT's Baja's in 14-33-15s (14-wide, 33 tall, 15 rim) I prefer "floatation" tires for mud and deep snow. Provided you do not "high-center" your rig, you'll float and go Again, it's a personal preference gained through personal experience.This is probably common knowledge among most forum members, but for those that may not be aware...
In addition to the tread pattern, snow traction is a function of the rubber compound and tire width.
Most tires (except for 3PMSF) have a compound that becomes relatively hard in cold temps. An aggressive off-road tire may be great in dirt and mud, but there's a good chance it will not perform well in ice & snow.
Width is also important. Under most conditions, wider = better performance (within reason). However, for snow-covered pavement, narrow tires perform better, because they are more likely to cut through to the road surface, rather than riding on top of the snow.
For example -- I was driving home from work one night around 11 PM. I-270 had a good 5-6" of snow on it. I was in my little '93 Nissan NX2000 (with about 4-5" of ground clearance) and narrow winter tires. The only other vehicle in sight was a lifted Suburban with what appeared to be huge off-road tires. I was in lane 1, and the Suburban was in lane 4. As I was slowly passing him, he sped up. I didn't want to be behind him so I sped up. We went back and forth like that for about a minute until the Suburban began to fishtail and then did a few 360's before coming to rest backwards, up against the Jersey wall.
