- First Name
- Kent
- Joined
- Oct 14, 2023
- Threads
- 24
- Messages
- 303
- Reaction score
- 314
- Location
- Gaithersburg, MD
- Vehicle(s)
- Bronco Sport; 350Z; Porsche Boxster S; Hybrid Escape
Mine seems stuck at 22.2 MPG. That's with the 3-cylinder 1.5
Ethanol is far higher octane than gasoline, but it has far less energy content. All other things being equal, more Ethanol means fewer miles per gallon.
Rethink that statement. They have installed a knock sensor on the engines....The problem is we haven't figured out how to change internal combustion gasoline engine compression ratio on the fly just yet.
So how can we tell when we are running on TWO cylinders?I've never measured it myself, but most references online suggest highway cruising requires on the order of 50 hp--a little more for faster speeds, a little less for slower speeds. The engine is literally loafing along at that power demand.
Cylinder Deactivation
The biggest innovation to the 1.5L EcoBoost engine is the cylinder deactivation.
During operation at partial load, the first engine cylinder can be deactivated hydraulically.
This reduces the fuel consumption and the emissions of the engine or vehicle.
If only minimal engine power is required, the system stops the gasoline injection and the valve actuation.
The connection between the camshaft and the intake and exhaust valves of the first cylinder is interrupted via a new camshaft module and a special rocker arm by means of engine oil pressure.
The PCM calculates the optimal time using the engine speed, throttle position, and load condition.
The intake and exhaust valves remain closed and enclose the mixture in the combustion chamber.
This should balance the forces acting on the cylinders by means of a kind of ‘spring effect’. The temperature within the deactivated combustion chamber is also maintained in this way, which increases the efficiency of the combustion when the cylinder is activated again. The activation and deactivation only take approximately 14 milliseconds. The system operates at engine speeds of up to 4,500 RPM. The friction and pump losses within the engine are reduced.
The fuel consumption and CO2 emissions decrease by up to 6%.
This is correct, but the parameters changed do not affect the engine's basic compression ratio--that's determined by ratio of cylinder volume with the piston at the top and bottom of its stroke. Changes to these respective volumes may be effected via changes to cylinder bore and piston stroke length, combustion chamber and/or piston shape, etc., but as mentioned, these are determined during engine design and production; they cannot be changed after the engine is running...yet. There have been some efforts of late to control engine compression ratio on the fly, but that feature is not in production yet (as far as I know).When the the sensor senses knocking (detonation of the fuel from compression and not from the spark) it is adjusting the operating parameters on-the-fly to eliminate the knocking (because it can damage our engine).
Thank you. That is a good explanation.… is usually accomplished by retarding timing, decreasing boost pressure, enrichening the mixture, or a combination of all three.
Retarding timing results in an instantaneous reduction of cylinder pressure (and a commensurate reduction in power) during combustion, which is the most effective means of rapid elimination of detonation.
Thank you.Cylinder deactivation occurs when coasting or cruising under light load conditions.
AI said:Ford Bronco Sport 8F35 Shift Programming
The Ford Bronco Sport’s 8F35 transmission uses a proprietary programming system, which is designed to optimize shifting patterns and adapt to various driving conditions. Here are some key points about shift programming in the 8F35 transmission:
Note: The Ford Bronco Sport does not offer a manual transmission option. The 8F35 transmission is an 8-speed automatic, and its shift programming is designed to provide a balance between performance, fuel efficiency, and driver convenience.
- Skip-Shift Technology: The 8F35 transmission employs skip-shift technology, which allows for automatic transitions between gears (e.g., 1-3-4 or 1-2-4) in certain driving scenarios. This feature helps improve fuel efficiency and reduces the need for manual shifting.
- Non-Skip-Shift Mode: When the transmission is in manual mode (SelectShift paddles), it uses a non-skip-shift pattern, allowing for more precise control over gear shifts (1-2-3-4).
- Gear Ratio and Shift Point: The 8F35 transmission’s gear ratios and shift points are programmed to optimize performance and fuel efficiency. For example, the transmission may shift into higher gears at lower engine speeds to reduce engine noise and improve fuel economy.
- Adaptive Learning: The transmission control module (TCM) continuously learns and adapts to the driver’s behavior, adjusting shift points and patterns accordingly. This helps the transmission optimize its performance and responsiveness over time.
- Resetting the Transmission: In some cases, resetting the TCM (transmission control module) can help resolve transmission issues by allowing the transmission to relearn its adaptive values. However, this procedure should only be performed by a qualified technician and may not resolve underlying mechanical problems.
I don't know. I would be surprised if these are published anywhere. Some tune vendors sell devices that can read, copy and write tune maps, but I don't know if you can see a map that you've copied.Where can we find the tuning maps for our car?
Very Nice. That would be th4 2.0 L, 4-cylinder engine with an official 20/24 MPG rating.This is the mpg my husband got this weekend with our 2021 BS BB on a 650 mi. round trip, all interstate driving at 70 mph normal mode. H
It's designed to be transparent, on the other hand there have been a couple of incidents posted on this board where the deactivation solenoid stuck in deactivation mode and the symptoms were low power along with the wrench symbol in the dash display lighting up.Thank you.
Is there any indication on our displays when this mode (2-cylinder mode) is active?
I found this massive 230 page report by FORD. Very impressive.I don't know. I would be surprised if these are published anywhere.
I am using an ODBD reader with Torque Pro software on my cellphone, and add-on PID definitions to display the tachometer and gear selection on my cell. I got the gear PID from the Escape forum and entered it manually into Torque Pro.And is there any way to figure out what gear we are in?
