Bronco Sport battery replacement (main and fob)
tommy
tom
First, the main engine bay battery is a little difficult to replace as the entire air box must be removed, careful to first use a knife to remove the plastic caps first on the nuts or you will damage them. I learned the hard way, can't find a replacement for the one I damaged. In my opinion Wal-Mart (Ever-Start) and Interstate Batteries are the best.
Second, key fob, it started acting up, so I ordered the CR2450 3V coin cell on Amazon cheaper than going to the store and got the name brand I wanted.
Pic attached, to remove;
Ford Bronco Sport Bronco Sport battery replacement (main and fob) Bronco Sport Key Fob
start at the end where the key is attached, I used my fingernail and found the sweet spot the removed the cover with a harp tooth pic.
Big Ben
Rick
Calgary
Before starting any DIY project, just check out YouTube. There are millions of how to videos by experts
Mwittke5857
Elma, NY
2021 Bronco
When the time comes, I plan on going the lithium ion route. Although not inexpensive, they weigh less, have 2-3x the power and last up to 10 years
tommy
tommy
tom
If you're referring to the fob battery I did go with the lithium battery.
tommy
tommy
tom
Yes, I did You Tube it, there were 2 videos, one guy forced the battery in and the other did it correctly.
cprcubed
Parker, TX
Can the BMS be setup for lithium ion batteries? They have different charging requirements. Cheers!
My understanding is that Lithium batteries can't be charged when it is below freezing. That seems like a big problem to me. They do make heated batteries, but that seems problematc on a vehicle that has trouble keeping a regular battery charged. One big advantage of lithium is that they can be charged much faster, so that might work well once heated up. Seems like on a short trip, it might not have time to heat up enough to charge the battery.
Rinzler
Philly
My 3 year and 3 month main battery is going. I have a jump box that has helped a couple times. AutoZone tested and confirmed it’s not holding a charge. I did watch those replacement videos. I priced out extension for rear bracket bolt and magnetic tool and may do it myself. Shopping for battery now. Was recommended Battery Warehouse as it’s cheaper and not a 2 year only
