Ac condensate drain line where is it
WalterT
Walter
Home
Can someone please tell me or show a pic of where this is so I can check if it is clogged? It is running down to the floor mats and not a drop coming outside to the ground d. I’ve read other posts about this but no info on where the drain actually comes out at. And how to get to it if not evident.
WalterT
Walter
Home
FOUND the AC condensate drain opening. And poked a coat hanger in there to free the clog that was causing dripping condensate into my floor boards.
It’s not a line but small pinched tube off the core.
That drains down onto the heat shield above the beginning of the muffler. Under the vehicle take the circled cover plate off. The opening is behind the shield where the u shaped muffler bracket is. Undo a few nuts that are holding the heat shield in place on the right axle side. Pull it down as best you can and you should see the opening at the top of the hump the muffler runs down. I shoved a flashlight in there to hold it back. Poked it with hanger and water all came out. Weird design but not too too much of a pain to fix. Didn’t seem like it was anything clogged in there more so the pinched off tube sealed itself up.
Ford Bronco Sport Ac condensate drain line where is it IMG_2651
Ford Bronco Sport Ac condensate drain line where is it IMG_2652
Ford Bronco Sport Ac condensate drain line where is it IMG_2648
Ford Bronco Sport Ac condensate drain line where is it IMG_2649
Ford Bronco Sport Ac condensate drain line where is it IMG_2646
Good work!! You cracked this one and figured it out!
Vinny429
Vincent
MARYLAND
1987 Dodge Omni
I'm a Ford Senior Master Tech and just wanted to let you know that your post was more helpful than the factory service manuals. Thank you
