TnyM
Tony
Seattle
'77 Chevy c10, '22 Bronco Sport BL
Installed. It was pretty easy, I made sure to take my time. I will say, use a good tape for anchoring the midpoint on the graphic because mine shifted a little causing the graphic to be off just the slightest bit (I do not care you REAAAAALLY have to look at it to notice it).
My decal had a few things missing/unfinished (attached photo). So double check your decal prior to sticking, because you can fix some of these issues.
- The upper right corner (drivers side windshield) appears that a sliver of decal is missing. I don't care about that one as much as it looks like the line is just thicker and I'm sure that would be a tiny piece that wouldn't hold anyway.
- I can see that a circle was cut but not removed from the vinyl. I can probably peel it out myself but since it's already on my hood I may just leave it.
Other than that! Fast shipping, packaged REALLY well, and the customer service seems great.
Robins21
Horse Pasture, Virginia
I purchased their hood bump graphics but have not put them on yet.
TnyM
Tony
Seattle
@Luis@UG just sent you a message! I have an idea.
Robins21
I finally got a nice stretch of days where I could clean the hood & get the hood bump decals installed. Not perfect but it adds a nice look to the Bronco Sport.
Luis@UG
Luis
Houston, Texas
2022 Ford Bronco
Wow, well done with the install. That came really good.
Thank you for sharing it.
Luis ?
James
Lewes, DE
2024 Bronco Sport
Has anyone tried putting the hood decal on a Shadow Black Bronco Sport? I want to do something about the glare, but I'm not sure how the matte black on gloss black would look.
Luis@UG
Luis
Houston, Texas
2022 Ford Bronco
We have Solid/Solid Pinstripe, Topography Single Color, Topography Two Color (photo below) and if you choose just to remove the glare, we offer the Hood Bumps Anti-Glare PPF.
if you have more questions or doubts, please let me know.
I'm here for y'all
Photo shared from a friend and costumer @EARLSAYS
EARLSAYS
Earl
Houston
Yep - Underground Grapjhics the the best!!!!!! My outer pieces aren’t usually included in that kit, I had them make those later - helps a ton
