Front grille loose, missing connecting bolt or pin.
freqnc
NC
Hello!
The front plastic panel/grille surrounding the lights is loose on my 2022 BS BL.
You can see from the attached picture because it's missing a bolt or a pin above the light on the drivers side. The dealership says it needs to replace the whole grille part to fix it... would it go under warranty?
I noticed this after I took it in for the lights flickering recall which makes me belive it's their (un)doing.
Does anyone know - would it be possible to fix it myself? Does anyone know what part and how to put there?
I'll appreciate any help on this!
Ford Bronco Sport Front grille loose, missing connecting bolt or pin. IMG_3460
Bronco7221
Christian
Dodge Nitro
Hi!
Did you ever get this resolved? Mine is missing on the passenger side and I was looking to see if I could find a part/clip when I came across this post.
Any info you have would be appreciated!
Hello!
Hi there! Will you send us a message with your VIN and your local Ford dealer? I can look into things on my end.
Quashish
Tomas
Sacramento
2024 Bronco Sport Badlands
if you didnt want to deal with leaving your car for a whole day to fix this you could take the bolt out from the other side and take it to an ace hardware and match it up. they have lots of screws, springs, heim joints, rubber washers all kinds of diiferent useful stuff in those bin sections.
