Bushwacker Fender Flares U-Clips
ncjoe1970
2022 Ford Bronco Sport Big Bend
Trying to find some Bushwacker Fender Flares U-Clips.
Has anyone purchased just the U-Clips?
Already had several fall off my 2022 Bronco Sport Big Bend.
Dantanman
Dan
Mabel Lake BC
Terrible fastening system. My dealer installed rear flare has fallen off 3 times. Lost it on the highway last time. Waiting for response from dealer. These should be bolted on. C clips are not holding.
Alfa 2407
Thomas
Looking to get replacement clips myself, but I have come to the conclusion that the clips need help, once I get new clips I will be modifying the flares to use 3m double sided tape as well, already using only 3m ob one as I lost all the clips and didn't want to be driving around with only half a rear flare, I removed the weather stripping and replaced wit 3m and added some of the bottom as well, this is the solution I recommend.
Tigger
Tigger
Illinois
How did this work for you?
I also lost some clips but no fault of Buswhacker as me and tree became good friends. But yes, called company and they are sending new clips and Ford is doing the reinstall and checking the other clips. All for free, so that’s real nice.
Alfa 2407
Thomas
Still holding up, I'll post pictures when I get off work
Alfa 2407
Thomas
Before
Ford Bronco Sport Bushwacker Fender Flares U-Clips 20240131_141401
After
Ford Bronco Sport Bushwacker Fender Flares U-Clips 20240131_141353
I just took these, the after is my driver side rear which kept falling off, before is passenger rear, after applying the 3m tape, I used some black silicone so dirt wouldn't keep getting stuck on the 3m, note I never got replacement clips
BBQ Crew
Tony
Philadelphia
I lost clips also. Do you have the number you called to get new clips? I cant find the correct number. TIA
Tigger
Tigger
Illinois
I do not recall but I do remember you have to call the wrong number provided on the internet and then they give you the right number. It’s a pain, but only way I knew.
I think it was this number I initially called:
RealTruck at 800-234-8920
BBQ Crew
Tony
Philadelphia
Thank you. I will give it a try
Mwittke5857
Elma, NY
2021 Bronco
When you get your new clips, also get some 3M double-sided tape (PN 03609), place it on the inside lip of the openings. That will (1), stick the flairs in place and (2) add an ever so slight thickness to the whole shebang and the clips will actually snap into place. Worked for me, your milage may vary
