Transmission fluid pressure switch
Becky
Detroit
Sport won’t go in reverse and will not accelerate over 40mph. Anyone else has any problems with this? I’m wondering if it’s covered under the power train warranty, as my bumper to bumper has expired.
Becky, it’s not possible to diagnose the mechanical issue causing your malfunction based solely on your description of the symptoms, therefore no one here can say with accuracy if repair(s) to fix it will be covered under warranty. The warranty document that came with your car outlines specifically what portions of the powertrain are covered by your warranty. If you don’t have a copy you can track one down with a brief Google search (look for Ford new vehicle limited warranty). Make sure when your service department tells you what they will do to repair your car you know what is and is not covered.
Did the dealership tell you the problem is the Transmission fluid pressure switch?
Mysportmakesmehappy
Becky
Detroit
No I was out and about when I returned to my truck and started it the problem presented out of nowhere. I immediately drive to the nearest auto part store and had them scan it. It came back with two transmission fluid pressure codes.
Hi there. Can you please send over a message with your VIN and the name/location of your local Ford dealer? I would like to look into these performance issues you have been experiencing on my end.
Mysportmakesmehappy
Becky
Detroit
Ok. My Sport has been repaired. This weekend I’ll be making a new post with a detailed report of what the problem was found to be. I will say that the customer service at both, the dealer and Ford HQ has been phenomenal!
Ibrahimsy
Ibrahim
Saudi Arabia
Ford Taurus 2021
Sorry to revive an old thread, but I have the same issue, suddenly no reverse and limited gear in drive, 2 codes for the pressure sensor. Please could you share how you got yours fixed? I’ve been told it’s the pressure sensor inside the transmission
