BS Badlands Lift kit
DosJotas
Dominican Republic
I love my BS in the street, on the road and off-road. I'm still learning the best setting in the GOAT dial when off-road.
I got the lift kit from Eibach.
PRO-LIFT-KIT
2021-2023 Ford BRONCO SPORT Badlands 2.0 T AWD C2
+1.0" Front | +0.7" Rear
Part #: E30-35-053-03-22
Set of 4 Springs
Comment: DESIGNED FOR USE WITH OE SHOCKS
Now I'm not sure about the tire size.
Should I go with 245-75-17 since I'm not planning to change the wheels.
Here's how it looks with OE tires
Ford Bronco Sport BS Badlands Lift kit PXL_20231105_162922345
Ford Bronco Sport BS Badlands Lift kit PXL_20231105_162909344
Ford Bronco Sport BS Badlands Lift kit PXL_20231105_162947529
245/70/17
Oops, my bad, should be 245/65/17. I'm running 245/70/16, which is how I confused myself. That and the tire size you listed seemed like a typo.
Goodland
Jake
CA
One dude will chime in to tell you 235/70R17 fits but not sure if it will rub off road.
A ton will say 245/65R17, lots of people run it.
A few will say larger (255/65R17) if you don't mind trimming the pinch weld.
A lift does not change the maximum tire size, which is generally accepted to be 245/65R17. The limitation is at the rear of the wheel well, not the top.
Some true measurements will vary based on manufacturer, so one 235/70 may fit while another rubs. We're talking about millimeters of difference at this point, probably best to shop 245/65R17.
RPYLE50
Rowdy
Missouri
Random question: How do you like the Eibach lift springs? I am thinking about getting some for my OBX but doing more research before I make the dive! Your BS looks great BTW! If it were me, I'd ride with 245/65/17. I have had multiple tire dealers tell me that size combo would work (or 245/60/18 if you have an OBX).
DosJotas
Dominican Republic
Ok. What size would you get?
DosJotas
Dominican Republic
So far, very good. Still very comfortable on the road which is my main use and great for off-road. Bur I need better tires, I'm still with the OE 225 65 R17
Goodland
Jake
CA
Planning on 245/65R17 Wildpeaks, most likely. If someone wheels 235/70R17 and confirms zero rub in all off road conditions, I'd look at a set. HRG lists 245/65R17 as the max without trimming, and they look like they put their BS through the paces. I think it's literally 5mm height difference between the two sizes I mentioned here though.
DosJotas
Dominican Republic
Interesting choice
It may perhaps be more helpful to think in terms of overall diameter rather than specific sizes. Tire size from a manufacturer can give you an idea of a tire's overall diameter, but it's not a guarantee. In other words, a 245/65R17 tire from one manufacturer may have a different overall installed diameter that one from another manufacturer.
DosJotas
Dominican Republic
It may perhaps be more helpful to think in terms of overall diameter rather than specific sizes. Tire size from a manufacturer can give you and idea of a tire's overall diameter, but it's not a guarantee. In other words, a 245/65R17 tire from one manufacturer may have a different overall installed diameter that one from another manufacturer.
Ok. I'll check the Falken wildpeak AT3W
Goodland
Jake
CA
Interesting choice
For the driving I do, the Wildpeak a/t Trail is probably going to make the most sense. I *might* get out to a truck trail every other weekend or hit the desert a couple times per year, the rest is like 95% highway. I like how some more aggressive tires look, but not worth a noise/mpg tradeoff for me.
The Rinzler
Tony
Everett, WA
PRO-LIFT-KIT
Set of 4 Springs
As a BS BL owner with 245/65r17's (without a lift) if I had a 1 inch lift I would go 245/70r17's, personally.
Iam a first edition badlands owner 10 months ago I had 235/70/17 Goodyear wrangler at 30 inch fits perfect, no lift needed, I do no off road driving.
Ford Bronco Sport BS Badlands Lift kit IMG_1199
