- First Name
- Sherman
- Joined
- Dec 1, 2021
- Threads
- 29
- Messages
- 1,826
- Reaction score
- 1,881
- Location
- MIDDLETOWN, MD
- Vehicle(s)
- '22 Badlands ordered 12/17/2021 - Arrived 3/25/22
Damn! Using a car-top carrier (or trailer) really has an impact on the ATF service interval!This is from the 2021 BS owners manual
Other Maintenance Items4Every 20,000 mi (32,000 km) Replace the cabin air filter. Every 30,000 mi (48,000 km) Replace the engine air filter. Every 100,000 mi (160,000 km) Replace the spark plugs. Inspect the accessory drive belt(s).5 Every 150,000 mi (240,000 km) Change the automatic transmission fluid. Replace the accessory drive belt(s).6 At 200,000 mi (322,000 km) Change the engine coolant.7
4Perform these maintenance items within 3,000 mi (4,800 km) of the last engine oil and filter change. Do not exceed the designated distance for the interval.
5After initial inspection, inspect every other oil change until replaced.
6If not replaced within the last 100,000 mi (160,000 km).
7Initial replacement at 10 years or 200,000 mi (322,000 km), then every five years or 100,000 mi (160,000 km).
If the vehicle is used in exreme conditions the the service interval are shorter
Towing a Trailer or Using a Car-top CarrierAs required Change engine oil and filter as indicated by the information display and perform services listed in the Normal Scheduled Maintenance chart. Inspect frequently, service as required Inspect rear axle and U-joints. Every 30,000 mi (48,000 km) Change automatic transmission fluid. Every 60,000 mi (96,000 km) Replace spark plugs.
Extensive Idling or Low-speed Driving for Long Distances, as in Heavy Commercial Use (Such as Delivery, Taxi, Patrol Car or Livery) Short Trips that do not allow the engine to get to operating temperature causing fuel dilution and an increase of the engine oil levelAs required Change engine oil and filter as indicated by the information display and perform services listed in the Normal Scheduled Maintenance chart. Inspect frequently, service as required Replace cabin air filter.1 Replace engine air filter. Every 30,000 mi (48,000 km) Change automatic transmission fluid. Every 60,000 mi (96,000 km) Replace spark plugs.
1 This is an optional feature.
Operating in Dusty or Sandy Conditions (Such as Unpaved or Dusty Roads)Inspect frequently, service as required Replace cabin air filter.1 Replace engine air filter. Every 5,000 mi (8,000 km) Inspect the wheels and related components for abnormal noise, wear, looseness or drag. Rotate tires, inspect tires for wear and measure tread depth. Every 5,000 mi (8,000 km) or six months Change engine oil and filter. Perform multi-point inspection. Every 30,000 mi (48,000 km) Change automatic transmission fluid.
Exclusive Use of E85 (Flex Fuel Vehicles Only)Every oil change If ran exclusively on E85, fill the fuel tank full with regular unleaded fuel.
From 150,000 miles to 30K?
I can see how constantly towing a 2,000 lb.(+) trailer with a large frontal area would lower the recommended change interval, but a car-top carrier?
I suppose THIS would be a substantial additional wind load at highway speeds:
