Correct file?
Mrmike
Syracuse, New York 13219
I own a '23 OBX. I currently have sync version 3.4.23188. I just downloaded the free map update Ford offers. The file name is Sync 32 and has 3 sections. Sync my ride, Auto install, and don't index. Is this the correct file for my map updates, and do I just install it like I did for 23188? Does this file only effect the maps or the whole sync system?
PugDad
Bronco Lilly
Newfoundland,Canada
BSBL
Yes that is correct. It will install similar to your Sync Version 3.4.23188 update. It is for Maps only.
If you need any help go to this thread,Sync 3.4 Build 22251 Default Issue and ask for Dude, he is the maps Guru
Jmuns
2022 Bronco Sport BL
You’ll need to also move the downloaded license key file into the Sync My Ride folder
Mrmike
Mrmike
I have my USB loaded with the following.
Syn 32 (decompressed)
4UST-14G424-CF.TAR.GZ
Is this what I need for the download?
Jmuns
Yes. But within the Sync 32 decompressed file you should have the 3 files you listed in your first post. You want those on the drive but not within the master Sync 32 file. And then you want to move the 4UST-14G424-CF.TAR.GZ zipped file into the SyncMyRide folder.
This is what your drive should look like, and the SyncMyRide folder
Ford Bronco Sport Correct file? Screenshot 2023-09-08 at 9.57.11 AM
Ford Bronco Sport Correct file? Screenshot 2023-09-08 at 9.57.19 AM
Mrmike
Mrmike
Excellent! I think I got it. We're vacationing to central Ohio next week. I will try to upload the new maps when we're on the way home just in case there is a problem. Thank you everyone for your help and expertise with this problem.
