Steeda strut tower bar with lift kit
ragone25
alex
new york
2022 bronco sport
I was wondering if anyone tried to install the steeda strut tower bar with a spacer lift also installed. I got my bronco sport lifted using the FordRangerLifts 2 1/4” lift and the 2 bolts that hold the strut to the frame are coming through the bottom instead of top down. The steeda bar requires the bolt to be put in from the top with a nut on the bottom but that wont work with these spacers. Was thinking about using a coupling nut to hold the strut to the frame and then find a short bolt to mount the bar to the coupling nut.
CyberSparky
Delone
Earth
2021 Bronco Sport, 1995 Ford Bronco, 1981 Ford Bro
Yes, I have it installed. Once you've added the lift an bigger tires it really helps on the highway at higher speeds or if the road has alot of wear that causes the tires to pull one way or the other. Worth all 110$ I paid for it. I didn't think it would help much cause the strut towers already tie back into the firewall, but it did. I have a different lift though. Can you use a rod coupler and a washer on your stud and then put the bolt down into the coupler?
Ford Bronco Sport Steeda strut tower bar with lift kit IMG_0575
ragone25
alex
new york
2022 bronco sport
Thats what i was thinking about doing. Just dont know what size coupler i would need. Ive found a couple but they seem long and looks like it might interfere with the hood closing.
CyberSparky
Delone
Earth
I’ll measure the inside diameter to see what size coupler will work, do you know what the thread pitch is on the bolts that come through are? I’ll try and find the correct coupler you’ll need but I believe you’ll need to drill out the internal “washer” that’s welded inside and use a bolt and washer pulling from the top at that point due to distance it sits off of the strut tower.
ragone25
alex
new york
2022 bronco sport
So the bolts are M8 with a 1.00 pitch. The only couplers I've been able to find are M8x1.25. Ill see if I can remove the inner bolts holding the spacers on for the lift to see if I can replace them with a M8x1.25 bolt. i'm pretty sure they are carriage bolts so I should be able to find replacements with the correct threads. The only coupling nuts that would fit are from china so I don't know how much I'd trust those.
ragone25
alex
new york
2022 bronco sport
Update: the bolts on the spacers are welded on so coupler nut is the only solution if i can find the correct size
CyberSparky
Delone
Earth
Ok, I’ll measure the depth and width of the opening with a caliper when I get home from work and update this post with the measurements.
ragone25
alex
new york
2022 bronco sport
How did you remove the two connections that have to be rerouted to not interfere with the strut bar? I cant find a clip or anything holding them on and I dont want to just yank them out
CyberSparky
Delone
Earth
I didn’t have to re-route anything to install mine. I literally removed those 2 bolts, set it down and put the bolts back on. Add an image of what you’re referencing and I’ll have a look at mine.
Sorry I didn’t give the measurements, I had to go out of town for work and forgot about this till now when I received the email notification.
Mrmike
Syracuse, New York 13219
When I installed the strut tower bar on my '23 OBX (no lift), I had to put one line over the bar rather than bending it.
Ford Bronco Sport Steeda strut tower bar with lift kit 100_6575
ragone25
alex
new york
2022 bronco sport
Thanks I finally got it installed. Just got the coupling nuts today and still took a little work to get it to fit. Had to use a step bit on both side to widen it out so it would slide on.
Ford Bronco Sport Steeda strut tower bar with lift kit IMG_4245
Ford Bronco Sport Steeda strut tower bar with lift kit IMG_4246
Colonel Angus
Dean
New York
Same here.
Ford Bronco Sport Steeda strut tower bar with lift kit IMG_2090 2
GoHack
Gordon
Palmdale, CA
Just purchased the Steeda Strut Tower Bar today, w/a Lift Kit on the horizon.
