Fuel Injector Recall
Went out to the garage a couple of days ago and smelled gas fumes. I popped the hood of the BS and checked. No leaks. I then stepped over to the 67 Camaro, and discovered a fuel line was loose at a clamp. A twist of a flat blade screw driver, and all is well. I wonder if the "valleys" of the intake manifold were designed to allow leaking fuel to puddle, and keep it away from the hot manifold (or in my case, headers)?
I checked online, and could not find a TSB for 1967 Camaro potential fuel line leaks due to loose clamp.;)
I know this is meant to be tongue-in-cheek, but did you actually find puddled fuel on the manifold?
Yes, passenger side, between cylinder 2 and 4. Fuel filter runs across these two into the Holley carb.
I tightened the clamp, and snugged any others. It is kept stock in look, otherwise I'd be installing Earl's hoses and clamps.
Chevy should issue a recall on ALL 67 Camaro's!!!! :crackup:
Funny man...everyone comes from miles around to hear the funny man talk.
One of my 401K retirement packages.
Ford Bronco Sport Fuel Injector Recall Engine
