Windshield washer low pressure
Lanedfritz
Lane
DFW
Has anyone had an issue with their windshield washer pressure? I have a BS Badlands 2022 and the pressure only sprays about 1/5 of the way up the window. Very annoying
basser5150
Basser5150
Greenville, SC
2023 Bronco Sport Badlands
I have a 2023 BL and have the same problem. I think this is "normal". Yes very annoying.
CLR
Chris
NorCal
Agree! The spray on mine only reaches about half way up the windshield. Not ideal.
Jill
Gillian
Oakville, Ontario
I have a ‘21 Badlands and my washer sprays perfectly.
Flash
I have a '21 Outer Banks and the spray almost goes over the top of the Bronco.
Have you checked the fluid lines going to the sprayers to see if there are any kinks?
Major Kong
Major
Right Here Right Now
Bronco Sport aka "Spark Plug"
compressed air
directed at spray nozzle tip
reverse direction of fluid spray
possible tip clog issue
try to remove hose to reservoir to pass the kidney stone
CLR
Chris
NorCal
In my case, I think they just need to be properly aimed. There is plenty of pressure.
They make a fine stiff metal tool for adjusting these nozzles. I got mine when I did a google search for it years ago.
Hello! Could you privately message us with your VIN and the name and location of your Ford dealer so I can look into this windshield concern? Thank you!
