Fuel Injector Recall
V8 Yankee
Harold
Miami
21 Bronco Sport
FYI all, finally had the Fuel Injector recall issue fixed. Actually only the drain tubes installed which is somewhat not a fix but more like way to mitigate a leak if an Injector cracks and starts leaking. Honestly feel it is a sketchy way to address the problem if it really becomes a problem. I called Ford out on this and what they offered me was basically an unlimited warranty on the fuel injectors should they ever need to be replaced. I can live with that however a leaking fuel Injector, drain tube or not is not something I want to think about. A class action suit is in the works that focuses on this issue. It's in the discovery phase now so too early to say where it will go. Just an FYI for all, hope no one actually needs the funky drain tube but at least it's a start.
The only good thing that might come of this class action suit is that the discovery process could reveal the failure rate of these fuel injectors compared to other vehicles. Given the NHTSA has already looked at the data and (apparently) determined injector replacement isn't necessary, I'm skeptical this lawsuit will tell us anything of value. The lawyers might make a few bucks if Ford decides to settle, but unless your car is one that caught on fire I seriously doubt owners will get a payout of any significance.
V8 Yankee
V8 Yankee
Harold
Miami
21 Bronco Sport
Probably right, one other concern is how the Injector issue will affect resale value. May not be a concern, for thought, the legal team at Ford is probably aware and is preparing. The lawyers developing the case are looking at a potential 30% recovery fee for themselves. Just wait and see how it unfolds.
onceforall
Fresno
F-150
Just rec'd my BS BB, built late February. Happy to provide photos of "something new", if indeed Ford did anything to the injector itself, or changed manufacturer. Not sure where to look just yet, but if there is an older photo somewhere that can be posted, I can take the same on my end.
It's been addressed before; this is not an injector issue. The injectors used are like any other injector on autos...they can crack, and leak. The issue here is if the fuel from leakage can drain away and not ignite easily.
V8 Yankee
V8 Yankee
Harold
Miami
21 Bronco Sport
Yes, I think we all know that, hence the drain tube fix. These particular injectors have a higher structural failure rate than other makes and models of cars, trucks and SUVs. Ford has just now, at least here in Southern Florida just started to schedule the effected vehicles in for repair. Or in this case installing a funky drain tube. Make sure Ford gives you the unlimited warranty for the FIs. For myself I haven't received anything formally from Ford, just the word of my Service Manager.
We just purchased our sport a few weeks ago, so I'm not sure if the fix was already done by the dealership already. I'll wait another few weeks, then contact them to see.
It was purchased in north central Florida.
Do you have any evidence to support this? I've looked far and wide on the internet for data regarding fuel injector failure rates and I can't find anything to suggest the injectors used for the 1.5L Dragon engine are any more prone to failure than other injectors. If you have a source please share it.
I see and have read the Ford recalls in both links you provided, but I did not see that the recall specifically states your statement of "These particular injectors have a higher structural failure rate than other makes and models of cars, trucks and SUVs."
My source, Ford recall notice.
The recall notice says nothing about an increased likelihood of a cracked injector relative to other vehicles. It says "There is a chance the fuel injector can crack..." which is a possibility with ANY car.
V8 Yankee
V8 Yankee
Harold
Miami
21 Bronco Sport
I'm not sure what your point is. If you need more information talk to your Ford Service Manager. The are the experts. My info came from Ford Corporation and my Ford Dealer. Read up on the subject, I've relayed enough for you to do a deep dive. After that share what you learned, that's why this forum is here.
But you made a statement: These particular injectors have a higher structural failure rate than other makes and models of cars, trucks and SUVs.
I'm only questioning that, as I have not seen anywhere that Ford stated this.
I do agree to have the TSB performed.
