Bronco script emblem installed
Any thoughts on which looks better?
One said it was oem but didn't come in that packaging. It's metal and said 3m on the back , but is flat dull.
The other is China, unknown adhesive, plastic, and shiny .
Ford Bronco Sport Bronco script emblem installed 20230218_103851
Ford Bronco Sport Bronco script emblem installed 20230218_103940
The 3M is just the adhesive material on the back.
I wasn't clear. One has adhesive on the back that is labeled 3m. The other one's adhesive is unlabeled and blue covered. So known (unless they're lying) and unknown
So I'm trying to decide if i want the possibly fake oem that is dull or the I know it's cheap and a fake that is shiny.
Ok, gotcha. See if you can find another OEM one online to check out the packaging/adhesive protection color.
Bamsi
Puerto Rico ??
Any idea on how to remove dealer sticker without damaging paint? Would like to trade it for a bucking bronco... :rockon:
Use a heat gun to soften up the adhesive, then work around the edges carefully with a plastic spatula.
BodieBronco
Houston
Bronco Sport 2023
Please send pictures when done ,thank you .
Installed!! New bumper guard, bucking bronco, and script.
The blue tape worked wonderfully.
Of course, after I finished and walked away from a further distance, I worried the driver's side is at an angle.
What do you guys think? Does the script and the horse look good enough?
Ford Bronco Sport Bronco script emblem installed Screenshot_20230221_121720_Gallery
Ford Bronco Sport Bronco script emblem installed 20230221_120810
Ford Bronco Sport Bronco script emblem installed 20230221_121101
Ford Bronco Sport Bronco script emblem installed 20230221_115901
Ford Bronco Sport Bronco script emblem installed 20230221_115840
Ford Bronco Sport Bronco script emblem installed 20230221_115941
Perfect looks amazing. Black on that blue looks correct.
Cactusjk
Jeff
Woodland Hills, CA
Looks great! How did you position and align the script emblem?
BodieBronco
Houston
Bronco Sport 2023
Look. Back at pg one JLR's post with pictures of his white bronco. He told me "Take a look , this might help .Buy 1 inch blue tape and match it to the hood joint and then 1 inch from the vent . That’s what I did if you like that look . Good luck ."
I followed his advice. I did one inch blue painter's tape next to the vent vertically, one inch blue painter's tape by the hood joint/ edge. Then i find the wider blue painter's tape was the same width as the script. So i put that down next, then another strip of painter's tape below that. Removed the wider space holding tape, and cleaned the area really well and with alcohol wipe. Then i doubled checked that the script fit in the space..removed the 3m adhesive covering, and applied.
Cactusjk
Jeff
Woodland Hills, CA
Thanks! Best to see the tape during install but I can work with that!
Actually jrl bronco is cactus gray first edition. Yes sometimes it looks white .
Ford Bronco Sport Bronco script emblem installed 63C77056-ACB7-4E13-94CA-F3D0329D1944
BodieBronco
Houston
Bronco Sport 2023
Sorry I didn't think of taking pictures during the process. You got this though. It wasn't difficult. I just took my time and double checked. When i put the bronco on the back, i taped it on with blue tape just so i could step back and look at the placement in relation to everything else
BodieBronco
Houston
Bronco Sport 2023
Oops, thanks for correcting me. It's really sharp looking
Reactions: Jrl
Tomp611
Maryland
2022 Bronco Sport Big Bend
Did you all opt for matte or polished script emblems?
