Hack to connect the two piece Back OEM Rubber Mats for the Sport using Chicago Screws.
Wolf256
Jane
Kingston, WA
2023 Bronco Sport Atlas Blue
Your back mat has a Bronco emblem on it? Mine doesn’t ?
Virgo Life
Virgo Life
USCGRescue
Ford Bronco Spot Badlands 2022
Those were the FORD OEM part that cost me $250
So now I'm cryin
Snake Eyes
Western PA
Bronco Sport Badlands 2023 Atlas blue
It looks cool… but I’m pretty sure this hack is easier or this is probably just how Ford intended them to be put in. You just put the smaller mat against the over hanging piece so it is secured tightly against the side. Once put in it doesn’t move at all.
Ford Bronco Sport Hack to connect the two piece Back OEM Rubber Mats for the Sport using Chicago Screws. 8C40D1B2-3F78-4747-86E9-7E88D10D26E9
Ford Bronco Sport Hack to connect the two piece Back OEM Rubber Mats for the Sport using Chicago Screws. 01E94C4C-BFD6-4D81-9227-973E52DEFF6D
Ford Bronco Sport Hack to connect the two piece Back OEM Rubber Mats for the Sport using Chicago Screws. E6297248-4A56-4FAC-93BC-0D4758CBA9D2
Bill G
San Gabriel Valley, CA
Just because anything that can go wrong will . . . If you put the piece coming down over the tunnel inside the floor mat (over the lip) any fluids, sand or dirt will drain into the floor mat and not go down between them and under the mat as the video portrays.
Not a bad mod, but if I was going to go through all the effort to locate and drill stuff, I would just add some tonneau snaps instead of the screws. Easier to take apart and put back together. Under $10 in hardware either way.
Agree with the other poster, the lip goes into the other pan. But you could tuck it for a while like that and let heat do its thing. Eventually it will always line up in correct position.
