Anyone have the Rally Innovations light bar?
BroncoNamedSarge
Leslie
Belton TX
Bronco Sport Big Bend
I installed mine, don't think theres much wiggle room but maybe a little. The light bar does sit a little above the lower opening so I was a little worried when installing but it worked as before the install. I do travel under a couple over passes everyday with the adapt cruise on and have never experienced anything not normal. So strange, I'll add a close up pic of mine to compare.
Ford Bronco Sport Anyone have the Rally Innovations light bar? bar1
Ford Bronco Sport Anyone have the Rally Innovations light bar? bar2
Not sure mine looks that different from yours.
BroncoNamedSarge
Leslie
Belton TX
I run the rally Innovations bar with the lights pointed down. I do have 360+ and everything works great, adaptive cruise included.
Ford Bronco Sport Anyone have the Rally Innovations light bar? PXL_20220608_134211243
what wheels are those?
thanks
Winds of Change
Chicagoland
If holes were drilled differently and the cross bar mounted where the top of the bar is level with the top of the bumper I bet that would make a lot of difference. I,ll figure out the plate thing another way.
BroncoNamedSarge
Leslie
Belton TX
I have a trigger 4 wireles set up I keep the controller clipped to the center console. I think it would look nice with the diode dynamic lights upfront.
Ford Bronco Sport Anyone have the Rally Innovations light bar? 20220216_120448
Curious how you ran the wiring from the engine area into the cabin. I just installed lights on my rally bar, but couldn't really figure out a good clean way to run the wire to the switch inside the cabin. Any help is greatly appreciated.
Wabarca2
Walter
are you installing the trigger 4
BroncoNamedSarge
Leslie
Belton TX
Is it like a 2" black round rubber thing? Do you have to drill in it? Sorry for the 20 questions.
lordwally
wally
oregon
2022 bronco sport
I got BS BB to, do cutting needed? for the nudge bar?
