Dark
Northern VA
On to our fourth set of tires. Yokohama Geolander G015 @ 265/65r17 on 17x8 +40 wheels.
Really happy with the traction, noise, and ride quality with these (all of which were concerns on the KO2's we had).
Minor rubbing of the pinch weld at full lock but haven't experienced this in our daily routine--I'll be trimming it back regardless.
Overall, think we found the final tire choice. :whew:
Ford Bronco Sport What did you do TO your Bronco Sport today? sid
Ford Bronco Sport What did you do TO your Bronco Sport today? rear
Ford Bronco Sport What did you do TO your Bronco Sport today? quarter
Ford Bronco Sport What did you do TO your Bronco Sport today? center_ca
AndyMac204
Andy
good to know someone that has tried a few different tires out. these ones look solid, nice choice!
There are a number of really good reasons why should not trim those pinch welds. Trimming pinch welds for a body-on-frame car is fine--the welds provide no structural purpose. The Bronco Sport utilizes a unibody frame, and the different body parts support and transfer structural loads between each other. If you weaken the connection (the welds) between those parts you may compromise the frame's structural integrity.
Dark
Northern VA
Correct.
I haven't inspected the pinch weld yet but if I could get away with removing enough to retain the spot welds then that would be an option. The other option would be to fold it over--sacrificing some rigidity but retaining the seam and metal.
At the end of the day I'm not concerned with the trimming impacting the structure considering the location and amount of material to be removed.
I'm not an automotive structural engineer, so I can't tell you whether or how much trimming will compromise structural integrity. Be that as it may, structural integrity is not the only concern. Manufacturers also apply a sealant between the two pieces of metal to prevent corrosion. Again, I can't tell you whether or how much trimming will compromise corrosion mitigation. Structural integrity and corrosion prevention are pretty important issues for me, so I wouldn't base any decision on guesswork.
Bending them is probably a lot safer option.
Dark
Northern VA
It's absolutely recommended that seam sealer is reapplied or, at the very least, some appropriate paint. Even with folding it over one should consider seam sealer inside the fold and paint or sealer on the outside as paint will most likely be chipped away during the process.
I'm more concerned with trying to retain the liner or alteration of the liner so the metal is protected from debris wear.
Hooligan88
Holli
MN
Mazda CX-5
1) Aeroskin Hood Deflector.
2) Rear Bumper protector.
3) Color matched Tufskinz lettering. I have the complete front/back set, but decided to try covering just the SPORT on the tailgate.
Ford Bronco Sport What did you do TO your Bronco Sport today? FA7A1C7C-FC64-4AE8-BF20-5F055B881146_1_201_a
Ford Bronco Sport What did you do TO your Bronco Sport today? FC33ADEB-792A-4D31-BC75-1D72CB9F9B5D_1_201_a
Ford Bronco Sport What did you do TO your Bronco Sport today? 0A28C59D-3212-4D2D-9339-56A251737018_1_201_a
Ford Bronco Sport What did you do TO your Bronco Sport today? E35EB57E-D32D-42D9-9FC6-208DC02E7223_1_201_a
Is the rear bumper protector from Ford?
Blue oval fan
Nick
Greenville, SC
22 Bronco Sport
BS had a busy week.
Dropped off the BS Tuesday to get XPEL ppf installed. Partial hood, fenders, a-pillars, headlights, painted bumper stripe, partial roof. I do lots of highway driving, this will keep the front end looking new.
Also had a bunch of Ford points to blow. All the parts finally came in today. About an hour to install everything.
-Front and rear mud flaps.
-Rear bumper protector.
-Ford perimeter plus.
Also removed those small air deflectors that were in front of the wheels. Feels exactly the same. No difference in mpg.
Ford Bronco Sport What did you do TO your Bronco Sport today? 20221020_115316
TxHill
Todd
Katy, Tx
BS had a busy week.
Just installed same mud flaps but I couldn’t resist coloring in the embossed lettering to make them stand out more. Look’s especially good against my black and white OBX. :sunglasses:
Ford Bronco Sport What did you do TO your Bronco Sport today? B03F5FD8-7779-4415-9115-D1C06961396D
