Switch Panel Location
Winds of Change
Chicagoland
Are there any clean install locations for a switch panel. My BS BL is scheduled for 11/22. I am looking for a good unobtrusive location. What have you found?
dakman
For me I needed fast easy access to my switches because I use mostly the back lights but often turn on the lights which aren't street legal. The left side of the dash around the area of the oem light switch, under it is all open and a good spot but I found could be a prob possibly getting in and out of vehicle for me. I put two switches into the dash piece of the factory switch. I can reach without looking and switch either-or both. Directly below this area if it works for you is easy to work with. I couldn't find any place I liked for a nice switch panel that didn't interfere or look out of place. Seen some nice setups on this site some guys have done.
Ford Bronco Sport Switch Panel Location PXL_20220521_222512704
Winds of Change
Winds of Change
Chicagoland
I like that. Maybe a smaller rocker switch to eliminate the protrusion.
dakman
I use them all the time, up is backlights, middle off, down brites. The toggles make it very easy to find and switch quickly. I'll prob replace with some nicer metal toggles that light up.
