Tufskinz grille/hatch letters for sale on Ford Accessories
Bronco Blue
Brian
Illinois
2022 Ford Escape
So are they like stickers or is there more to the process of putting them on? I’ve been thinking of getting them, but I’ve never had stuff like this before with cars that I’ve owned so I don’t know how they work or how they’re installed.
LazyDirtFarmer
Chicagoland, NE Illinois
pkmed
V
Midwest, USA
2023 Bronco Sport Outer Banks
I have been searching the forum and wanted to bump this thread. Has anyone tried these and have pictures?
https://www.levittownfordparts.com/sku/vn1pz-9942528-be.html
They are also made by tufskinz. I want to eliminate the white outline and these are 3 layers of doming resin, paint, and adhesive. The online chat said they fit over and completely black out the letters eliminating the white outline from vinyl stickers. Hoping someone has used them and has pictures. Thank you!
From what I have seen on here, none of them completely cover the letters (even the tuffskinz). If that is what you are looking for, then Plasti-Dip is what you need. You mask off an area around the letters (slightly bigger rectangle) and then spray the whole area with the stuff (lay it on thick). Then you can peel it off the paint while leaving it on the letters.
pkmed
V
Midwest, USA
I saw that on here too. I'm not sure I'm up to the challenge ? But I may try that first.
Upon further investigation, I think the ones I linked are the exact same as the ones listed earlier in this thread from a different seller.
