Bought it might as well install it
If the water is THAT deep I'm sure he'll have worse things to worry about ...
I was not thinking deep,, I was thinking water spraying up there.
I’ve had bigwater spots dried up all over my breather box.
I figured it sprayed up there some how.
bjbena
Barry
Escape SEL. EcoSport SES
Stay out of the water.
Deep puddles, I dunno bout that.
You said 'deep' in your comment ...
fourthgear
florida
He also said he didn't know about that.
Deep water will throw more water every where , so it doesn't have to be water over the hood .
Did you put it on a dyno before the swap & after , I'm curious on how much HP /T you gained & see if the MPG changed . I have used K&N on just about every car/truck /HD I have owned & really never saw a difference in any performance .
I will not be using one on the BS or my Sprinter , because its a diesel & not sure if they even make one for it . I will use factory type filters on both .
RiotfunK
Mass
22 Bronco Badlands
The k&n and other intakes aren’t going to do anything but give you sound. Unless you’re tuning, exhaust etc the whole works you aren’t gonna see any gains. You’ll see more dust in your motor though. The race vehicles running these get rebuilt and worked through frequently. The BS only when something breaks.
That_kodiak_brown
Maurizio
Long Island, New York
I did not dyno I just did it for the sound ?
That_kodiak_brown
Maurizio
So I ended up removing the intake and putting the stock one back. The sounds and look was my favorite but there was just this slight drone inside the cab that I just couldn’t live with?. Super easy install so I can switch back rather quickly. Should’ve spent the money on some h and r lift springs (which I’m ordering soon) ?
bjbena
Barry
That's too bad as it looked pretty good.
The 2.0 Liter is the only real way to go for more power.
24,000 miles now in the mountains with my Base model, I’m good.
Winds of Change
Chicagoland
I figured the piped in sound was enough lol.
Cyber Sport
Maryland
What is your problem, it seems all you like to do is make negative comments, picking apart members posts. It seems obvious people posting on the forum are look for help or just want to share. I think you need a time-out.
