Similar, Toyota does more burnt colors also yellow being the color on top.Went Toyota colors on the bronco
If your rails are anything like my Badlands, the cross rails can only be put in one place. The roof rails have holes on the underside for the cross rail mounts. Only 1 set of 4 holes total for the cross rails.![]()
Roof rail cross rails finally came in to the dealership more than a month after I first picked up the car... Not sure why it took so long since it was on my original order as a dealer installed option (you'd think they'd know whether or not they need to order it themselves or whatever...) But regardless, they came and I had them installed today. I might space them out a bit more when I get home, push the rear ones back a little farther or something. Either way, they'll just sit there and look pretty until it comes time to use them ?
Slick!Puppy barrier built and installed. Just need to pull out the headrests to remove it.
Wow that turned out awesome!Puppy barrier built and installed. Just need to pull out the headrests to remove it.
should seek patentPuppy barrier built and installed. Just need to pull out the headrests to remove it.
Can I ask why you didn't get theToday it is 63° & sunny so I decided to install the AVS vent visors & AVS Aeroskin hood protector on my wife's BS/BB. I got the flat Aeroskin hood protector not the one with the bump.
Can I ask why you didn't get the hood protector with the bump? Does yours still kick away all the highway bugs?Today it is 63° & sunny so I decided to install the AVS vent visors & AVS Aeroskin hood protector on my wife's BS/BB. I got the flat Aeroskin hood protector not the one with the bump.
That looks amazing! Can I ask what fender flares you used, and specs on your wheel and tire combo? Man, that looks sooo good!Custom rims, larger tires, lift, raptor fender molds with powder coating on the rivits, powder coated tow hooks, spare swing gate, tint, and relocate rear camera … lots of work!
Top three pics are before … last three after. Will take more soon ?
