- First Name
- Mark
- Joined
- Oct 30, 2021
- Threads
- 119
- Messages
- 6,731
- Reaction score
- 13,153
- Location
- St. Jacob, IL
- Vehicle(s)
- 2021 Badlands | 2020 Escape
- Thread starter
- #1
This video from a mechanic is about a 2021 Bronco Sport that needs a new engine. Why? Because some genius at Jiffy Lube overtightened and stripped out the oil drain plug. This, of course, allowed all the engine oil to drain out, and the driver thought they could make it to a shop. Wrong!
If you take your car to a shop for regular maintenance be sure you check their work. For oil changes, check the oil with the dipstick before you start it and make sure it was refilled with fresh oil. Start the car and let it idle for a few minutes before leaving, then bend down and check underneath for oil leaks. Any big leaks that will kill your engine should be apparent. Then check under it again the next morning or after it's sat in the same spot for a few hours. That should show you any smaller leaks, or spills the shop didn't clean up. And for Pete's sake, if the oil light comes on while you're driving pull over and shut the engine down immediately. The engine will self-destruct in very short order without oil.
