Missing Jack/Lug Wrench
Bbbs
Huey
My 2022 Big Bend is missing the lug wrench and the three-piece Jack handle crank. I've contacted my dealer and waiting on a reply. You might want to check your spare!
Major Kong
Major
Right Here Right Now
Bronco Sport aka "Spark Plug"
Bbbs
Huey
Maybe it's under the hood. I pulled everything out of the spare tire well and had a jack and a spare tire. The tray around the top of the spare tire well contained a small white funnel. The dealer is taking care of it tomorrow.
Ford Bronco Sport Missing Jack/Lug Wrench IMG_20220706_141220379_HDR
tburner
Troy
DFW, TX
Ford Bronco Sport Missing Jack/Lug Wrench 1657158482324
Op, remove the jack from the threaded rod
arrows indicate lug/jack wrench
Adding to Kong: To free the wrench, turn the nut on the left corner (as shown in the photo) to "lower" the jack. The wrench is hooked onto the jack, but closing it releases the wrench.
Sidebar: has "spare tire well insulation" been added to the list of things removed from the BS?
I think the sound insulation is trim dependent. My 22 Badlands has it.
Outback Texan
MIke
San Antonio, TX
I too keep a long 1/2 socket wrench beside the spare!
"Hello, Officer, I'd like to report a murder".
I also think the "trunk insulation" is part of one or more Ford Bronco Sport "sound insulation packages" that are only on the uplevel trims, not the Big Bends.
Bbbs
Huey
I'll pull the jack out and take it apart. Hopefully all the parts are there. Thanks
The spare tire well insulation is intact. It has a little white funnel in at.
Apparently the engine noise-absorbtion cover, and the under-hood insulation pad isn't included on the Big Bend or Base model. It's Standard on the Badlands, and the First Edition. It's also standard on most Ford vehicles with the 1.5L "Dragon" engine. I've ordered both parts.
I guess I should get the owners manual out and start reading, I might learn where the key goes! ?
Wait...there is a key?
Jill
Gillian
Oakville, Ontario
The funnel is for use if you need to fill your easy-fuel gas tank using a gas container rather than at a gas station. All Ford vehicles for many years have come with one.
