Instrument Display Menus Missing
Train
WALKERTON
BroncoSport
No select screens menu on the big bend. Your badlands likely has alot more menu options to go thru
thekingprawn
Dustin
Kingston, Wa
Right, I just don't see an option to display a Bronco nor a star/favorites option. Is that under the Select Screens menu? I'm beginning to wonder if these screens vary between trims.
On Badlands you can select which screens you want available in the display. I haven't found a way to customize information within the displays. On the other trims with the 4 inch cluster display there is a configuration view option.
WLK
Wendy
Is this the same for the big bend model? Mother got one last week and would really like digital speedometer in the middle of the cluster. Ive only seen a few options on the menu and none that change the display. Either a picture of a bronco, trip meters or nav is all i can find
I have a Badlands and I have the digital speedo on my cluster. I will take a pic and share it later today. Not sure if the Badlands has different options.
WLK
Wendy
Not my pic but mine looks like this. Trip 1 screen should let you see it.
Ford Bronco Sport Instrument Display Menus Missing 1657120003357
thekingprawn
Dustin
Kingston, Wa
WLK
Wendy
I consider that the perfect info screen. Is there a way to configure it on the 2022 Big Bend?
I think you just need to look through the screen options and see if there is a configuration option. My Fusion was great about configuring screens.
MENU
SELECT SCREENS (depress OK)
scroll up and down
thekingprawn
Dustin
Kingston, Wa
That's the Trip 1 or Trip 2 display for Badlands. Do the other trims not have all those bits of info on the Trip displays?
WLK
Wendy
Juliet
So I noticed about a month ago that I was missing most of my instrument cluster menus. I still have the trip summary screen (shows miles, mpg, and time), the fuel economy screen, the music/now playing screen, and my TPMS screen. Everything else is missing. Below are pictures showing what my settings menu looks like.
I had used FORScan to disable the double honk when exiting the vehicle and increase my tire circumference. I also tried to disable my DRLs turning off with the turn signal a while back but it didn't take. I've since reset to factory defaults by loading the backups I made when I first hooked up to the car but I'm still missing menus.
Anyone have any thoughts?
Ford Bronco Sport Instrument Display Menus Missing 20220529_105414
Ford Bronco Sport Instrument Display Menus Missing 20220529_105420
Ford Bronco Sport Instrument Display Menus Missing 20220529_105426
I literally just went through this issue! I needed to toggle down when "display settings" was highlighted . . . not just press okay.
thekingprawn
Dustin
Kingston, Wa
I looked at mine earlier, I have the 360+, so the left half of the bottom of the screen as all the adaptive cruise stuff and the right side has the digital speedo.
WLK
Wendy
I went and took an actual picture of mine, looks the same as the other pic.
Ford Bronco Sport Instrument Display Menus Missing 1657141880356
thekingprawn
Dustin
Kingston, Wa
Mine with the intelligent cruise, lane keeping, etc on.
Ford Bronco Sport Instrument Display Menus Missing 20220706_144604
The OP has a Big Bend. They have a different display / dash compared to OB and BL. We need someone else with a BB to chime in here.
