Factory Installed Rubber floorboards...
TSBates
Chattanooga, TN
2021 Bronco Sport First Edition
  • Thread starter
  • Banned
  • #1
Your thoughts on these? Are they low quality that will wear through soon (how thick and durable are they and can they be replaced by Ford)? Has anyone supplemented these with aftermarket products such as WeatherTech? It was awesome of Ford to think of this but did they go on the cheap when they actually designed them?
I took my fabric mats up but am thinking of putting them back in place since I don't want to wear out the factory-installed one...but doesn't that sorta defeat the purpose of the factory ones?
sticks918
Illinois
2021 BL, Area 51
I think you meant to post a link or photo... But in any case, I replaced my mats with the WeatherTech ones and they've been holding up great so far after about 12k miles. My only complaint is that the snaps that hold the mat to the floor are a little weak, a few weeks ago I was putting them back in after rinsing them out and thought I clicked them in all the way but apparently not because it came loose and went right into the gas pedal. Luckily it was still in park but definitely give those snaps a good press if you're reinstalling.
I brought the factory liners exactly for that purpose. They are replaceable. I keep my vehicles a long time and generally have to replace the mats as I wear a hole in them with my heel. The fact I’ve almost always had stick shifts may be some of the reason.
As for the quality often factory liners, they seem to match the Weather-tech as far as material and thickness. Just not as much coverage.
LilbroncoS
Brandon
2021 bronco sport
I have the bronco sport weather mats.. i like the material of them. They do there job.. i dont live in a place with a bunch of mud or snow so i dont mind the less coverage.. i used to get weather tech in past. Yes they do cover a bit more but they are just to stiff a material for me and things slide way easier on my old weather tech cargo mat than they did with factory ford
Honestly it's one of the reasons I'm happy I added the rubber mats from Bronco. They are perfectly fit and add a lot of rubber under foot. They look good too. Solves that concern in my opinion. Plus when they fill up with dirt it's easier to get rid of it.
TSBates
TSBates
Chattanooga, TN
  • Thread starter
  • Banned
  • #6
Maybe not all Bronco editions came with rubber flooring underneath the fabric matts...these are NOT removable---it is a liner built into the vehicle (see pic)...they would have to be cut out...
Flash sorta washes out the image but I think you can se that there is rubber underneath the floor mats....
PS: anyone who also knows what those dark stains are gets double points....seem to be dripping from above....
Ford Bronco Sport Factory Installed Rubber floorboards... Screenshot 2022-06-17 085944
LilbroncoS
Brandon
2021 bronco sport
Think we all just thought you were asking about aftermarket options .. i dont know how you would fix that
Only the Badlands and perhaps the Special Edition come with the rubber floor instead of carpet.
I would definitely get the OEM liners (rubber floor) version. Easy to take out to clean and will protect the original floor from wear.
What ever brand you go with, just make sure it’s for the rubber floor. The ones for the carpeted floors will not work.
TSBates
TSBates
Chattanooga, TN
  • Thread starter
  • Banned
  • #9
Where can you purchase the Ford inserts?
MJE
Calgary, AB
I picked mine up from EBay but just google the part number.
MP1Z7813300BA or MP1Z-7813300-BA
TSBates
TSBates
Chattanooga, TN
A hotlink would be kinda nice...
BigPhatPaulie
Matthew
Alberta, Canada
I got the ford floormats as they are way easier to take out and clean rather than trying to clean the rubber floor
TSBates
TSBates
Chattanooga, TN
Just ordered a set---I'll let you MOFO's know how they work out...
