Yep.. you are right.. Jan 14th...They have info only for the last time they moved the autorack. Once they release it they won't have new data until they pick it up to move again.
Where is it at now?TTGX 974626
It finally worked for me on the UP trace number. It turns out I don't speak the robot dialect of English very well.
My train is scheduled to be at the West Colton, CA interchange on June 11th at 8PM. I think it has to change lines near LA for the journey north.
It left Nogales, AZ yesterday at 4:12PM. So it's somewhere between Nogales and San Bernardino/LA, where it will switch tracks and head north at West Colton (San Bernardino) on the 11th.Where is it at now?
I'm jealous yours has actual information.It left Nogales, AZ yesterday at 4:12PM. So it's somewhere between Nogales and San Bernardino/LA, where it will switch tracks and head north at West Colton (San Bernardino) on the 11th.
I had to record it with a 2nd phone and listen to it about 5 times in order to understand anything.I'm jealous yours has actual information.
Hmmm, interesting technique. I may have to record mine on the computer and see if I can hear anything else I haven't heard on the last couple of listens.I had to record it with a 2nd phone and listen to it about 5 times in order to understand anything.
I just called UP for mine... ( Note: you can do it over and over by saying yes to another to trace, without hanging up ) here is what I figured outIt left Nogales, AZ yesterday at 4:12PM. So it's somewhere between Nogales and San Bernardino/LA, where it will switch tracks and head north at West Colton (San Bernardino) on the 11th.
You should call for mine since I suck at this apparently.I just called UP for mine... ( Note: you can do it over and over by saying yes to another to trace, without hanging up ) here is what I figured out
Loaded
Arrive
June 8 2:25pm
Interchange delivery
Gateway yard , Illinois
June 17 3:50 am
Ramp information
Gintester fo
That last part is "de Hermosillo, S.O." aka the Ford Factory.I just called UP for mine... ( Note: you can do it over and over by saying yes to another to trace, without hanging up ) here is what I figured out
Loaded
Arrive
June 8 2:25pm
June 17 3:50 am
Ramp information
Gintester fo
Loaded arrived June 9 3:57amYou should call for mine since I suck at this apparently.
That's exactly what I hear and none of it makes sense other than it was loaded at the plant, received by UP at Nogales on June 2, and it's arrived only gods know where early this morning. When I called Sunday morning after I got the autorack number I had a "departed" status. So where is it? Did it arrive early in Portland? Why is there no location stated?Loaded arrived June 9 3:57am
Industry June 11
Received Nogales June 2 1:35
Orgin gintester fo
And if you play it backwards you will hear a hidden message. Kinda like Stairway to Heaven.Hmmm, interesting technique. I may have to record mine on the computer and see if I can hear anything else I haven't heard on the last couple of listens.
Try using this with your VIN at the end:So my order status page now says Railcar Loaded in the Transit stage, but still no window sticker comes up when I plug in the VIN. Kind of sucks!
Nope, still says check back later. Ended up paying $7.99 at Monroneylabels.com and it came up instantly.Try using this with your VIN at the end:
https://www.windowsticker.forddirect.com/windowsticker.pdf?vin=
