BS Base model GOAT modes simply disappeared
NPeartrip
Rochester, NY
2022 BS
Turning the GOAT dial, nothing happens. No light, no display, no fault…Disconnected and reconned neg battery cable to redo system. Still no GOATs. Anyone have this?
ScareCrow
Burl
Indiana
BS/Badlands
Well that's a new one! Haven't seen that anywhere on the forum......
Only thing I can think of is checking the fuse box, under the passenger side lower panel.
Edit: This is all I could find ......... Looks like a call to Ford Service will be needed. But might help others for Fuse box info.
NPeartrip
Rochester, NY
2022 BS
Thanks. Will try. I also thought of that but did don’t know which fuse.
I'd say your goat dial isn't connected. Maybe the plug fell out. Did it ever work?
Up to you if you want to rip it up and check or let the dealer do it. A couple people have demonstrated how to remove the panel on the console over in the cupholder threads.
Ford Bronco Sport BS Base model GOAT modes simply disappeared Captur
NPeartrip
Rochester, NY
2022 BS
Thanks that seems like a plan. I mean it worked just fine and then, nope. Nada. It
does seem like a fuse blew or it is unplugged. I’ll report back. Thank you.
RiotfunK
Mass
22 Bronco Badlands
Wasn’t bad enough that Ford’s not shipping them with parts to save dough. Now they’re taking features back
It’s new OP and you have a warranty.
Don’t screw around with it.
Take it in, duh ~~
Joseph
Joseph
Ontario, Canada
Just wondering if you got this fixed because mine just did the exact same thing.
