Ford Pass cannot connect?
Ecromer
Ethan
Gerogia
My 2022 badlands cannot connect or activate on our Ford pass app. We have had the car for two weeks now. Since it will not activate on our app, we still have not gotten our points from purchasing the car. We have gotten a few different errors, but usually it is a message saying that the ford pass app cannot change the authorization to activate this vehicle.
List of things I have tried:
Calling dealer- "Well it could take a month to activate.... just wait"
Calling ford support- "We have no idea, we will call back with an answer" .... its been over a week since I called.
Deleted app.
Tried different phone.
Tried new account on app.
Unplugged battery for two hours
Did the whole close vehicle door hit lock button two times reset thingy that is some kind of master reset.
Reset the sync system
Updated sync system
probably thirty other things I am forgetting.
Anyone else have this issue or an idea for a solution. I do not care much about the app. I just want my points.
Have you tried logging in to owner.ford.com? I recall seeing something about using the same email address on the app as you use at Ford's website.
Deleted app.
Updated sync system
Hi there. Can you send us a DM with your VIN and dealership info? I can look into this for you.
Ecromer
Ecromer
Ethan
Gerogia
Yes no luck there. I can sign in and see my car. But I have zero points. It says I must activate my vehicle from the app before they will transfer over.
Major Kong
Major
Right Here Right Now
Bronco Sport aka "Spark Plug"
As above from Mark S.
https://www.ford.com/support/how-tos/sync/sync-3/how-do-i-activate-fordpass-connect-using-sync-3/
The points will take a while
I recall mine were well beyond two weeks time
I've had my BS almost a month and a half
Still waiting for my extended warranty to show up on the app
Dealer reply : "As for the warranty , my finance manager confirmed that the warranty is active in the Ford system which is pulled by your VIN at any Ford dealer in North America. The Ford Pass app unfortunately doesn't always carry over that info from the Ford system."
Ecromer
Ecromer
Ethan
Gerogia
It is not that I am waiting on the points, I cannot get the vehicle to even activate. On my app it still says activate vehicle and when I try it fails and gives me error messages.
Bronco307
Kade
Wyoming
22 Badlands, 22 Big Bend
I had the exact same problem with my 22 Badlands. The dealer couldn't figure it out and neither could Ford when I called them. I deleted it from the account, reset it in the vehicle settings, and then unhooked the battery for about 20 minutes. After that it loaded up and worked just like it is supposed to. The Ford representative said something about it being stuck in "transit mode" so it could not be set up and they weren't able to get it to work remotely. I tried a bunch of different things but ultimately deleting and unhooking worked for me.
HomePeace
Bay Area, California
2022 Bronco Sport Big Bend
Check your paperwork. Did you buy Ford Protect or did your dealer sneak in some third party warranty? My dealer switched me to some First Protect crap sold by Assurant. I cancelled it and went with Ford Protect with Granger and after signing the docusign, it was on my FordPass almost an hour later.
Major Kong
Major
Confirmed
Ford Protect
App function still wonky
went to pay using app points a couple days back
show clerk points on phone app 42,000
he says "take the items, well catch up with it later"
Kodiakbear
Southern New Hampshire
2021 Bronco Sport Outer Banks
Deleted app.
Updated sync system
I had the same problem with ours, the dealer couldn't get it to connect either.
I found that if the BS is parked near other vehicles it may not connect. I drove to a higher elevation, out in the open and it connected no problem.
HomePeace
Ya I had the same issue on the points. Picked up the floor mats with points, they weren't deducted. Went in to order the sill plates and made a comment that the points were never deducted. He pulled it up and showed they were "claimed" by the dealership and other orders from the same date and later were already marked complete. Sure enough as I leave, FordPass pushed a notification that the points were finally removed off my account. Only took 8 days.
The order for my bumper protector, cargo storage and cargo mat at a different dealer came off instantly as I was still awaiting to pay the cashier.
