Largest BFG all terrains with 1.5” lift and no rub?
kapk22
2021 Bronco Sport, 2021 Jeep Wrangler
I’m trying to figure out the largest we can run without rubbing and trimming. Probably getting 18s as well and the HRG lift on a big bend
29.5” = 245/60/18 = 245/65/17
GulfCoastBronco
Topher
Corpus
i am actually not finding the BFG all terrain ko2s in the 245/60r18 size. Did you find them somewhere?
BFG does not have good options in 18”. If you’re looking for 18, might have to try other brands. I’m running Toyo 235/65/18 and it’s a 30” tire
I didn’t go looking for the BFG specifically for you. As stated though the BFG’s have limited sizes in 18”. From all the postings I have been reading about tire sizes, a 29.5” tire is the ”safe” maximum tire size. I have not seen anyone with this tire size in different brands/models of tires have any issues with rubbing. If you go up to 30”, that seems to be the point at which most tires will require some trimming. You have to realize that tires with the same size printed on them can be a little different in actual measured size. A 245 width tire can vary from 240-250 and the other dimensions will vary along with that. I think that the BFG’s are ones that appear to vary to the larger side of the spectrum in each size.
You would think the tire width and ratio would spell it out completely but it doesn’t. You have to look at the exact specifications. Comparing revolutions per mile seems to be the most accurate measurement of actual diameter.
kapk22
yeah, I forgot about that. Thank you for the help
Look at Yokohama Geolandars just for shits n grins.
