Window motor going out?
Cursed Bronco
Dakota
Indianapolis, IN
Hello everyone!
I went to get in my car this morning and roll the windows down and was met with this God awful whine from the front passenger side. I have a video comparing the sounds on either window.
Has anyone experienced this before? A whining electric motor typically indicates failure or close to it from my experience.
What do you guys think?
It sounds like the motor is straining. Did you check for any obstructions in the window tracks? Make sure the tracks are properly seated in the window frame as well.
This doesn't seem likely to me, mainly because I believe the motor has a safety feature to shut itself off if it senses an obstruction. But you never know...
Hello everyone!
Good morning! If you send over a DM with your VIN and Ford dealer info, I can look into your concerns on my end.
I'm just spitballing here, but the first thing I'd do is make sure the battery is fully charged. Lower voltage increases the heat and resistance in the motor. That in itself shouldn't make a noise, but it may have damaged the motor.
I know I've burned out several cheap air compressors by not running the engine while running the compressor.
Cursed Bronco
Cursed Bronco
Dakota
Indianapolis, IN
That's a good idea. If you notice in the video, I am in a parking garage. I often come out to my car and put in Accessory Mode to run the radio and charge my phone while chilling for 10-15 minutes a couple times per day.
I did check the tracks like Mark said and didn't notice anything. The noise still hasn't gone away so I'll likely end up taking it to the dealer.
