What brake fluid
Mrmike
Syracuse, New York 13219
My OBX is a little bit low on brake fluid. All I have at home is Dot 3, and Dot 5 brake fluid. Can either one of these be used in my OBX?
MKC1911
Virginia
2024 Bronco Sport
Dot 3 should be ok unless it's really old. Don't use dot 5 it's a silicon base & won't mix with your current fluid.
DWG
New Jersey
Page 361 of the 23 Owners Manual.
BRAKE FLUID SPECIFICATION
Use fluid that meets the defined specification and viscosity grade.
If you do not use fluid that meets the defined specification and viscosity grade, it could result in:
• Component damage that your vehicle warranty does not cover.
• Reduced brake performance.
Note: We recommend you use Dot 4 Low Viscosity (LV) High Performance Brake Fluid meeting WSS-M6C65-A2 specifications or ISO 4925 Class 6 standards. If you use any fluid other than the recommended fluid, it could cause reduced brake performance and not meet our performance standards. Keep brake fluid clean and dry. Contamination with dirt, water, petroleum products or other materials could result in brake system damage and possible failure.
ELCouz
Canuckistan
