Vehicle Network Communication Error
AlexBell
Alex
Tampa FL
2022 Bronco
2022 Ford Bronco Sport 1.5L – Complete Electrical/Network Failure – Looking for Diagnostic Help
I’m working on a 2022 Ford Bronco Sport 1.5L EcoBoost that suddenly developed a major electrical/network issue while driving.
The vehicle was in Drive when suddenly all the warning lights came on, followed by the instrument cluster completely shutting off. A “Vehicle Network Communication Error” message appeared.
I shut the vehicle off, and afterward it would not start back up.
I initially suspected the battery, so I installed a brand-new battery, but the problem remains.
Current symptoms:
  • Instrument cluster: completely dead
  • Ford logo: does not appear
  • Fuel pump: does not prime
  • Relay(s): clicking
  • OBD-II port: has power
  • Scan tool: powers up but has NO communication with the vehicle
  • All fuses have been checked and appear good
  • New battery installed with no change
  • Vehicle does not start
Because the scan tool has power but cannot communicate, I’m suspecting a CAN/network, Gateway Module, BCM, PCM power/ground, or another module pulling down the network.
I’m currently planning to check CAN resistance between OBD pins 6 and 14, as well as power/grounds to the Gateway/PCM and the major network modules.
Has anyone experienced this exact issue on a 2021–2023 Bronco Sport? If so, what ended up being the cause/fix?
Looking for any known failures, TSBs, wiring diagrams, ground locations, or diagnostic procedures that could point me in the right direction.
Haven’t heard of that issue before
But you said you were working on the 2022 Ford Bronco Sport 1.5L … can you provide details on what you were working on, did you buy the vehicle new and is there any know previous history of electrical problems?
fjbear!
sam
mississippi
2024 bronco sport
Current symptoms:
Sounds like u are starting out doing the right things. Remember the grab a bundle of wires and wiggle test .
Fordforgood
doug
OH
21 bronco sport
I had an issue something like that no dash no start it would remote start. found no comms with ecu. i unplugged ecu and reseated plugs issue hasn't returned
