Turn signal indicator
RobD59
Rob
Georgia
2023 Ford Bronco Sport
Yesterday out of the blue, my right turn signal indicator started blinking really fast, I got out and checked the lights, they are both working as normal. no bulbs out. The left turn indicator is working normally as well. Anyone know what might be the issue or impending issue that makes that makes this happen? I was thinking maybe a solenoid on it's way out?? Thanks in advance for any help trying to figure it out.
tucg15
Tony
NJ
2023 Ford Bronco Sport Big Bend
This happened to me a couple weeks ago and it was the brake light. Most likely that is the issue.
burned clutch
steve
hemet ca
2022 bronco sport
same thing happened to my 22. couldnt figure it out at first and was and 6 dollar brake light bulb! you tubed a video took 15 minutes to replace. never seen a turn signal affected by brake light but it seems the system senses a different load and thus rapid blinking. makes sense actually
lori559
Lori
Tacoma Washington
ford
Very same thing just happened on my 2024 Bronco sport. My outside blinkers are working. My right brake light is out, so you might want to check your brake light. I’m wondering if this is happening a lot to the bronco sports I only have 5900 miles on my car and I haven’t even had it a year.
Reactions: Me3
Been there done that. Happened in 2021, replaced bad brake light bulb, no problem since.
