- #16
What is your starting psi on the Toyo open country and how high does the psi go after driving. Mine at at 36 cold but after highest driving they go as high as 39 psi. Is this too high?
It's not too high as in unsafe for the tire if that's what you mean.What is your starting psi on the Toyo open country and how high does the psi go after driving. Mine at at 36 cold but after highest driving they go as high as 39 psi. Is this too high?
https://www.tirerack.com/upgrade-garage/what-is-maximum-load-inflation-pressure-for-a-tireWhat is your starting psi on the Toyo open country and how high does the psi go after driving. Mine at at 36 cold but after highest driving they go as high as 39 psi. Is this too high?
Higher air pressure is used when the tires are mounted at the factory to set the tire bead to the rim.Even though it came from the factory at 40osi roughly.
