Tow hooks/ Tow hitch
Ozzy1275
Osvaldo
Denver
Benanza
Ben
NJ
I did call ford and ask about this and they informed me that a single hook cost around 200+ and I'm not sure I'm willing to spend that much on just one hook
Try and find a take off... Most of the nudge bars require them to be removed
Ozzy1275
Osvaldo
Denver
That might not be a bad idea I definitely like the look of the bs with the nudge bar
baja_bob
Bob
michigan
21 Bronco Sport
I would be careful yanking too hard on anything mounted to a unibody, just imagine the damage done by someone in a F250 with a tow chain, parts are coming loose or coming off. As much as I like these bronco sports their not meant to be buried up to the doors, there's a lot of suction in deep mud trying to pull a truck out.
Ozzy1275
Osvaldo
Denver
Yes that makes sense I understand the capability of the bronco sport if it's even in a situation like that you know someone messed up. I'm more interested in having some type of point for a minor situation where you just need a small tug or a little helping hand.
baja_bob
Bob
michigan
21 Bronco Sport
Yea, I've been there before, made many dumb decisions off-roading.
Stay away from chains, or even snatch straps. Stick with kinetic ropes.
I think your best bet will be to install a tow hitch on the back. The factory tow hooks are not going to do you much good unless you also have the bracketry welded to the unibody frame on the Badlands.
Give it time and I believe an enterprising vendor will come up with an aftermarket solution for front mounted recovery options. I think there's demand for a winch mount that will fit the Bronco Sport, and anything that can serve as mount for a winch will work fine for a recovery point as well.
Ozzy1275
Osvaldo
Denver
Give it time and I believe an enterprising vendor will come up with an aftermarket solution for front mounted recovery options. I think there's demand for a winch mount that will fit the Bronco Sport, and anything that can serve as mount for a winch to will work fine for a recovery point as well.
Yeah I think your i can't imagine that some other company won't come up with a way to add the front hooks
compass crusher
Nathan
linktr.ee
Here's possibly a solution.
A nudge bar install can be a tow point since it's bolted to the frame ?.
Ford Bronco Sport Tow hooks/ Tow hitch Screenshot_20230608-081510_Driv
Just a thought?
