Sync Navigation Map Update NA 2 21 Now Available
MNVKSFN
JAMES
ARIZONA
'22 BRONCO SPORT
I did both the Nav Maps update from USB and the Sync3 update (also from USB) with no issues.
After trying the Sync Reset mentioned in a recent post, if that does not work you could try the Master Reset and if that also does not work some suggest disconnecting the battery for 15-20 minutes.
And before going to a dealership, you could call Ford Software update support team and ask for a SYNC3 specialist (+1 (833) 389-0848 or Daniel at +1 (866) 631-3788 ext 76377) but I doubt they will offer more than the various resets for the problem you have now. Your install might be a partial install and interrupting the Sync3 update can cause the issue you have.
Master Reset
1. Review and Save Settings in order to restore Settings after Master Reset completes.
2. Start your vehicle. Ensure your vehicle is in park and running, not in accessory mode.
3. Press Settings on your vehicle's SYNC screen.
4. Choose General.
5. Scroll down and press Master Reset.
A message confirming that all system settings will be erased and reset to factory defaults will appear.
6. Press Continue.
A Resetting to factory defaults message will appear, the system will turn off and the screen will go blank. It may take a few minutes for the system to reset and resume normal operation.
And you could add on the key cycle procedure steps:
• Stop driving
• Ignition OFF / Stop
• Open and close driver's door and lock it
• Wait at least 2 minutes (ensure SYNC Display shuts off)
• Unlock / open driver's door
• Ignition ON / Start
Then:
1. Restore all needed Settings including to rejoin WiFi and adding your phone onto Bluetooth.
I have no screen to do anything with, it is black and you can nothing but turn the volume up and down. Nothing works but the start button and volume, well maybe heat but I am in Phoenix soooo don't really need that.
MNVKSFN
JAMES
ARIZONA
'22 BRONCO SPORT
Just got back in the car after sitting at the airport for a week and now all seems fine. Thank you all for responding
