Suspension Travel/Droop, W/WO Lift Info - Post Yours Here
Bluebaru
Post your info here.
1. What model do you have
2. Stock or lifted?
3. If lifted, what kind of lift do you have and how much? (spacer, springs, coilovers)
4. How much droop do you have, with the front end completely of the ground vs on the ground?
5. How much with one front wheel off the ground?
Measurement to be from top of tire to bottom of front wheel arch.
The reason I'm posting this. Does a lift affect your suspension travel and/or how and another member here told me he has substantially less droop, than me, on his Badlands, with a spacer lift.
Bluebaru
Bluebaru
2. Stock or lifted?
4. How much droop do you have, with the front end completely of the ground?
The reason I'm posting this. Does a lift affect your suspension travel and/or how?
1. 22, Badlands
2. Lifted
3. Flatout coilovers with a 2" lift and 14", 212lbs front springs
4. an average of 4.25" slightly diff left to right.
5. not measured yet
The reason I posted my spring rate is, I'm pretty sure that will affect both spring compression and suspension droop.
