Suspension swap (Escape OEM shocks, springs, and struts)
Hitman11
E
Houston
My 2024 Big Bend suspension was so uncomfortable that I decided to replace it with Escape Suspension components. The daily street drive is way more comfortable. Easy and low cost suspension swap for those not happy with the stiff ride. Definitely reduces the off road capability but makes the daily drive way more comfortable.
davidg4781
I’m kind of a noob at suspension stuff but did this have an impact on your ground clearance?
Deleted member 16210
What parts of the suspension did you swap?
Was it just shocks and springs ? Sway bar ?
How involved was this?
I ask because, I have a spinal injury and every
bit of suspension give, helps.
Hitman11
E
Houston
Spring and shocks for the comfort.
I also added steeda sway bar and engine bay strut bar for handling and trying to minimize the engine vibration.
Hitman11
E
Houston
It took me about 2 hrs total to swap all four corners in my garage using impact driver and basic hand tools. The rear swap was the easiest replacement of suspension parts I have ever done. No need to even get under the vehicle.
