Skid plate bolt missing on my First Edition
lbjailer
Walter
Apple Valley, CA.
08 F150 Lariat 4X4, Bronco Sport First Edition
I just bought a skid plate for the front bumper. When I got it, I looked under the car and noticed the rear bolt on the driver side was missing. When I put a bolt in the hole I discovered the nut plate is not present. Would this be a warranty repair or should I try and tap the hole to fit a different bolt.
See if the parts dept at local Ford dealer can get you one.
lbjailer
Walter
Apple Valley, CA.
I the nut plate is welded to the frame, and there isn't a way to reach the back side of the bollt to place a nut.
bjbena
Barry
Escape SEL. EcoSport SES
I doubt the dealer will cover it under warranty. By the nature of the part (skid/bash plate) they may just say it was damaged or broke off.
lbjailer
Walter
Apple Valley, CA.
Well I researched ford parts and see that it may be a nut plate, so I'm going to the ford dealer later to verify and get part if needed. Hopefully it is a clip on nut plate.
lbjailer
Walter
Apple Valley, CA.
The dealer said that the nut plate is internally welded to the boxed frame and cannot be repaired. So I will be tapping the hole with a 10mm tap and got a screw that will fit. Hope I will be able to remedy, otherwise I will have a useless skid plate I just bought.
Andrezzi
robert
PA
Anybody do oil change probably striped it out had one of mine crossed treaded
cprcubed
Patrick
Parker, TX
Can you use a Nutsert/Rivnut in that spot? Cheers!
lbjailer
Walter
Apple Valley, CA.
Never thought about that. I'll be looking into something like this. Thanks for the suggestion!
Also don't forget corrosion protection for the affected area. A hole with bare metal is begging for corrosion.
lbjailer
Walter
Apple Valley, CA.
I purchased a riv nut tool and inserts. I had to drill out the hole in the frame, but was able to install an M8 insert and it worked. I would never had thought about it without your suggestion. Thank you!
