Ripoff alert
Deleted member 12075
So my friend from work has a 2023 broncos sport badlands, and he's new to working on cars and stuff. So he likes to check on stuff with me. He took his car to chapman ford here in phoenix earlier today and his car has just under forty thousand miles so it's like brand new still.He takes really good care of it and he took it in for an oil change and a tire rotation, which is fine but first off they charged him $130 for it, which is ridiculous. Sanderson does it for $86, and you can do it yourself for about $40 although I will say, to do an entire rotation can be a pain if you only have one jack you have to put your car up on jack stands if you don't have a lift which almost no one does.
Anyways, the picture that I pasted below is the other stuff they said that he needed to get done. It's like eight hundred dollars in bullshit, and I know he doesn't even need the filters because he just changed them about ten thousand miles ago and I just checked them a week ago.
Also eighty one dollars for cabin air filter change. Do you get a blowjob with that like ehat the hell? It literally costs more than the engine air filter by alot like these are jobs that take a couple of minutes. that just tells you how much of a rip off this place is like so many other stealerships are.
I will say my experiences with sanderson have been good And they've never tried to pull this stuff on me but I usually end up talking to the service people beforehand so they usually know that i'm not stupid and I know even a little bit about cars but even before they knew me, they never tried to do that and they've been really nice to me with some other stuff, which is why I always go back to them and it's the only dealership I ever would recommend anyone go to.
Anyways, I just wanted to post this and let you all know.Watch out for this stuff.Don't let you or your friends or family get ripped off.Most of this stuff like fuel injector service, they just pour that stupid cleaner stuff that they sell at autozone.In by the way, you don't need it.There's no maintenance to fuel injectors.And if your fuel injectors are gummed up and having problems, you will know it.Because your car will run like shit.
I can't even imagine what a brake fluid service would be unless it's just changing the fluid, which a car with under forty thousand miles.Definitely, does not need or better not need.
Anyways, it doesn't surprise me.I know they do this stuff, but it's just god.It's so greedy, and this is what's wrong with the world.All this greed ruining everything and not letting you be able to trust businesses.
Ford Bronco Sport Ripoff alert IMG_20251023_205449
$114 for wiper blades? So basically $90 for labor?🤣🤣🤣
topspin34
William
Chattanooga, TN
2024 Ford Bronco Sport
Brake fluid should be flushed about every 50k miles. When the fluid heats up from braking(ie: long descents) it will condense and eventually rust internal parts.
Your individual results may vary.
I think I read where someone else had posted that you should change it every 20,000 miles. Or maybe it was after the first 20,000.
Rockboz
Randy
South Lyon, MI
If you feel that it needs to be flushed at 20k, I would consider upgrading the fluid. When I put upgraded rotor and pads on my MINI, we also upgraded the fluid and installed SS hoses.
DOT 3, every 20k
DOT 4, every 30k
