Replacement door emblem options
OBSASQ
Nebraska
2025 Bronco Sport/2023 Maverick
Understood. How useful exactly are they in reality?
They provide a tie down point if hauling anything on the roof rack. I would never use them - I'd like to remove them and replace with turn signal/running light inserts but I don't have the right length socket extension to remove them.
RM951
Ray
CA
21 bronco sport badlands
Has anyone removed the Sport block lettering from the liftgate?
Summers22
Summers22
Jon
I have seen where one person removed The BRONCO and SPORT both and then replaced the BRONCO only so it was in the center of the liftgate.
jj1
I don’t understand why! It’s not a Bronco,,
Summers22
Summers22
Jon
I guess they need to add "Sport" to the "BRONCO" on the grille.......
To answer your question, yes, it is very easy to remove the letters. They are held on with double sided foam tape. Easiest done when warm. Can be assisted with a hair dryer and fishing line. Then clean up residue with some “goo be gone”.
