Order tracker down?
loewymartin
MBMartin
Mine went into production same day as yours. Check ETIS to see if your ECUS are up and checked. ETIS showed all my ECUS up and checked on the 10th which is an indication it is built and coming off the line. And a date finally appeared under the in production yesterday which was the date for last Friday! LOL
I have gotten no emails from FMC so I am using ETIS and the tracker. I figure I will call the dealer in a couple days to see if it shipped and get the rail car# and then start tracking it that way.
ETIS shows absolutely nothing for me except the VIN. We are in the same batch (I'm 2307/2402) but I'm not built quite yet!
Rgill
Vegas
Las Vegas
2011 Toyota FJ Cruiser
I was 723/2402, so looks like you were a bit further down the line. Hopefully ETIS shows something in the next couple days for you. ?
MaxVelocity
Montana
1970 Bronco
Tracker finally working again for me today.
Krissy1228
Kristine
Delta, Colorado
Ford Bronco
Finally got a VIN and order number from the dealer and they were finally able to relay to us a build date of 1/24. The order tracker was working for like 2 days. The Ford order tracker will just refresh the input page every time I try to enter the info, and the order tracker in the sticky at the top of this forum just says unable to track this vin. Anything like this happen to anyone else?
That is happening to me as well. I do have a production date of 1/24 as well. Lets pray they continue to be on time with scheduling!
Tracker is working for me. Just checked. Still shows order confirmed.
fistpumpbruh
Karson
utah
2016 Focus ST st3
Well damn, I had a build week of 12/6 too, got my sticker but have seen zero movement after that. No computer testing, no word about build time/date... Getting really frustrated at the lack of transparency.
Rgill
Vegas
Las Vegas
Odd. Call your dealer and see if they can see a secondary status on your BS. What was your build with options?
My in production was sent on a Friday and looks like yours was Saturday. There is a chance that mine went through the build the next Friday and yours ended up in this week. A secondary status check should hopefully give more detail.
Rick Ford
Rick
Hudson, FL
It is usually the last time something was updated. Could be anything from the initial invoice to it going to production to just about anything. Technically most have found it a worthless date to track as it has too many unknown variables.
Thanks for the reply and I am finding that to be the case. I need to curb my excitement on every little change until I actually see the vehicle at the dealer. :)
loewymartin
MBMartin
So what does it mean when the "Activate Vehicle" button appears in FordPass? Does that mean what I think it means?! Is my Bronco Sport actually built even though nothing online shows that it is?
Rgill
Vegas
Las Vegas
It is the first indicator that your BS is actually on the line and almost built. Go and check ETIS for the ECU modules and that confirms it is coming off the line from what everyone says,
Ford Bronco Sport Order tracker down? 040DE0BA-6FEF-4151-95C9-3FC51CE324DD
PonyDriver43
Roger
NE FLA
9:00pm EST
Just checked Ford Tracker, it was “up”. My status changed from last night’s “Confirmed” to “IN PRODUCTION“. YEA!!!
No sticker yet.
Ordered 10/12
Orig scheduled week 12/6
Dealer advised 12/3 build now scheduled 12/20
12/14 In production
Now just hope for early in the week build.
Edit @ 9:30PM Just got window sticker from site mentioned in post #20. Date at bottom is today.
loewymartin
MBMartin
ETIS still shows absolutely nothing. Just the VIN - not a link to the VIN, just the VIN I typed in!
Rgill
Vegas
Las Vegas
After you typed it in and hit search and the bottom box I show below appeared was there any PTI link to the right of the box? At some point the PTI link should show next to box.
Ford Bronco Sport Order tracker down? 83858998-C8A1-4753-8D02-79B036FF1C6D
loewymartin
MBMartin
Nope, I don't have that link yet - I appear to still be in a holding pattern.
Ford Bronco Sport Order tracker down? 1639573446412
Rick Ford
Rick
Hudson, FL
After being in Production for almost 2 weeks, this morning I saw a long list of modules under the BCE column, but nothing under the PCM column. Does anyone know what this means?
