Badlands Height how much taller than other models/trims?
Blynne
Bridget
Cincinnati, OH
Anyone know how much taller, if at all, the BL is over the other models? I test drove an OBX and it had maybe an inch of clearance under my garage door. I read recently that the BL is a bit taller. I'm getting worried now that the BL I ordered isn't going to fit. :eek:
Rgill
Vegas
Las Vegas
2011 Toyota FJ Cruiser
Ford Bronco Sport Badlands Height how much taller than other models/trims? 802DD95E-D58A-490B-9134-445F636214B7
74 or 75 inch on my first edition , There seems to be about a half foot difference or there about parked next to a big bend . My garage is 7 foot , I have 6 inches clearance . If you don’t put bad lands or first edition crossbars on it you should be fine . Those are a little higher and are different than the other trims crossbars .
Ford Bronco Sport Badlands Height how much taller than other models/trims? C9DB11EE-4DD7-4600-A575-BD3C555358EB
Blynne
Blynne
Bridget
Cincinnati, OH
Yeah, I did not get the crossbars for that reason even though I really like the way they look.
Reactions: Jrl
Rgill
Vegas
Las Vegas
So you will be looking at 71.4 with the stock tires.
Blynne
Blynne
Bridget
Cincinnati, OH
Well, our garage is detached and built sometime after the house, which was built in 1958. It’s shorter than most and the OBX barely made it in so this should be interesting, lol.
The optional 235 tires add a small amount of height 3/8 inch higher if I remember correctly.
Rgill
Vegas
Las Vegas
Let some air out of the tires!! LOL :crackup:
ScareCrow
Burl
Indiana
BS/Badlands
Find a buddy with one of those 3 cylinder models and swap springs/struts. Then you have the lower ride height but keep the 2.0 engine.....:clap:
For a few bucks I would install a 9x7 new door problem solved . If you are handy . When I bought my 1957 Belair that’s exactly what I did , Owned and restored that car over37 years .
Ford Bronco Sport Badlands Height how much taller than other models/trims? BBDC5B65-397E-46AB-B3BD-FA870119EBA5
BroncoBob
Bob
Pennsylvania
Forester
I don't see any actual measurements here. My garage door is 73" I have an OBX on order but no-one can tell me how tall it will be with the stock antenna.
Blynne
Blynne
Bridget
Cincinnati, OH
I fixed the issue by ordering a shorter antenna from Amazon. It’s got plenty of clearance now.
