Oil Drain Plug Washer
Osmo66
Toronto, Canada
Good day, recently changed the oil in our BL but I didn't see any sort of washer on the drain plug.
Does anyone know if there is a part # for it and if this should be replaced each oil change? You can see the drain plug on the bottom right of the attached picture.
Many thanks,
O
Edit: Checked in at the dealership. For anyone wondering, the drain plug has a gasket on it and is meant to be reused. They said that you can keep reusing it as long as it is not cracked/damaged.
There is an o-ring attached to the drain plug.
Osmo66
Osmo66
Toronto, Canada
Thanks all, will pop by the dealership and see if they have any while picking up more filters
PonyDriver43
Roger
NE FLA
I recently did my first oil change (3000 miles) and when I removed my drain plug I also noticed no plug gasket. Looked like there should have been one to me. I wasn't looking directly at the pan drain, but stuck my finger around the drain and the washer came off on my finger. It was stuck to the pan. Looked good so I reused it. No leaks.
Yours may have dropped unnoticed into the drain pan.
