No really a Mod more like a fix....
Kraken23
Allen
St. Louis, Missouri
2022 BS BL
Hopefully someone can help me out here. I had 2 events happen in a short period of time, got the windows tinted (including a sun strip on the windsheild) and also had to get my windsheild replaced because of a rock chip that cracked. Anyway the issue I need help with is that one of those 2 events has resulted in the right (passenger) side of the plastic cover in the middle of the windshield above the mirror to become loose. I've looked at it and it seems like maybe there is now a missing metal trim clip because I can see the plastic clip part and the receiving "hole" part. No matter how many times I try to put it back it just keeps falling out.
Anyway I have found generic metal trim clips on Amazon but would like to know if there really should be one there or if something is actualyl now broken. Does anyone have access to a manual which shows that part and any associated clips that go with it so I could get a part number as cross reference it.
Thanks in advance for any help.
Either of those vendors could have broken the clip that holds the cover on.
Ant issues before the work was done?
Kraken23
Kraken23
Allen
St. Louis, Missouri
2022 BS BL
Can you send us a pic Pls?
I cant get a pic at the moment but here is a diagram I found online.
The item circled in yellow does exist as I can see it, the plastic "clip" is the part circled in red. I thought maybe that needed a clip as shown as HC1 on the left but that is shown going to a different plastic "clip" on the other side of the cover. Not sure if there is supposed to be one with the part circled in yellow or not, it looks like that comes with the cover.
Ford Bronco Sport No really a Mod more like a fix.... 1684176315113
Deleted member 6350
I’d go back to the windshield vendor and say hey one of your guys fu**ed up my cover and now it’s loose because someone broke the tab that’s supposed to hold it. Tell them that they need to order you a new cover.
If I were you !!!
