Thanks for the heads up. I have plenty of 3M automotive double-sided tape at the ready. If that fails, I also have that 3M polyurethane adhesive to back that up.Just an FYI, for you and potential other purchasers of the bumper guard-- I have the same guard and the double sided sticky tape was coming loose after about 2 months. To fix it I ended up adding LOADs more sticky tape to get it back down. Like adding 2x or 3x the amount of tape that was there originally. Since adding the extra tape everything seems to be OK.
Yeah, after installing it I ordered some more double-sided 3M tape. Definitely looked like a water trap underneath.I, too, had the guard lift up on my BS — (only it took @ a year). Seems like over time water and dirt get under turned up edges and turn sticky tape loose. Fortunately, they’re not too expensive to replace — just consider them “wear” items ?
