Motor/ Transmission Mounts Fail?
Poolmanz Sport Bronco
Bruce
Castro Valley, CA
sites.google.com
'21 Bronco Sport FE Area 51
Has anyone needed to replace your mounts yet? Should be under 5 years 60k miles powertrain warranty . I’m at 32k.
This started yesterday in the rain but looked at today. There’s vibrations in 1st gear to 2nd. Sounds like the driver side wheel is rubbing or it sounds like trail assist is active. Higher gears and rpm just fine. Reverse sounds like I’m closing an old treasure chest top when it engages.
UPDATE: Removed engine skid plate and found a rock lodged between the mount and plate- also cleaned out lot of dried out mud.
Hi Bruce! I can look into your Bronco's concern on my end. To get started, could you please send a private message over with the name/location of your local Ford dealer and your Bronco's VIN?
